First set were buggered after 2months ( although felt crappy after 1 month really until i figured out it was definitely them!)……creaking crown interface, and the bladder had blown up inside
Brand new set warranted, had one month, damping is shite again, annoying click in the first bit of dead travel and the negative / positive chambers aren’t working, which I’m guessing is causing the shite damping feeling….basically empty all the air and the forks suck completely down to about 50mm stanchion showing from a possible 150mm + ….. Start top pump the air chamber up, and nothing, then suddenly it moves, and then you have to pull at the lowers and get popping sound like pressure has been released
Carry on pumping upto desired pressure, and the forks just feel crap damping wise…. Release pressure and the same again 5 further attempts all the same, forks suck down, pump up and pull to release the last 20mm travel
And I get a crap clicking noise in the first 10mm of travel when pumped to disired, which I’m guessing is he damper goosed again! With no pressure and the forks sucked down, they feel nice, buttery smooth and no clicking, yet add the pressure and back to shit damping and a click!
Pahhhhhhhhh
Wish I’d have chose fox fit 34s now fed up! Any one else having issues with them?
