Bought a Norco Sight 2 SE a little under two months ago and have just completed the 30 hour service as recommended by Fox.
Somewhat surprised to discover that the damper-side leg contained no oil whatsoever, apart from a few drops of blue Float fluid that I use to lubricate the stanchions. I also found one of the circular seal springs rattling around in the bottom of the leg.
I’ve found no oil on the floor (or on the stanchion when riding) and am beginning to suspect the leg had little or no oil in it to start with.
Where do I stand with a warranty claim on this? Presumably the shop (who are going to call back) will want to send the fork off to Mojo for inspection but having had Fox stuff in the past that’s suffered terribly with lack of oil I’m not convinced that no damage has been done. even if it visibly appears OK.
Would you push for a replacement fork, or a written warranty from the shop agreeing to cover failure of the fork due to worn stanchions for, say, two years?
Cheers,
Dave.
