Needle bearings in ...
[Closed] Needle bearings in shock eyelets instead of bushings?
[#3754179]
Just going to order some and was wondering what peoples experiences were of them, do they last well and any noticeable difference?
Posted : 08/03/2012 4:19 pm
Yep I had some enduro ones from Real World Cycles in the states. Really good, massive stiction reduction to the extent that I needed more damping on the shock.
I never had any noticeable wear in a year of usage, where i had been getting through DU bushings about 1 every 2 months.
I'm back on bushings on my new frame though, mainly because the shock eyelet on my shock (RP23) seems to be too small and the bearings feel notchy in use. I think RWC now ship their kits with an extra bearing to fit undersized eyelets better.
Posted : 08/03/2012 4:24 pm
They're only meant to be fitted to the eyelet that moves the most which you'll be able to work out when you compress the rear. A needle bearing will tend to "notch" the race if it doesn't rotate much.
See here > http://forums.mtbr.com/shocks-suspension/enduro-shock-eye-needle-bearing-kit-580885.html
Posted : 08/03/2012 4:33 pm
From an engineering point of view........ they wouldn't seem to be a great idea.
Small amounts of rotation aren't great for them, and needle rollers will fail very quickly if any muck gets in there; there is no room for the grit to hide!
Bushes are the fitting for the job. Maybe try a higher spec bush. Also, replace the rubbish standard aluminium top-hat with a stainless one-piece job.
TFT or BETD perhaps
Posted : 08/03/2012 5:43 pm
Cheers for the info lads, retro83 you can get them for fox shocks from BETD but they only have the shaft in 22mm length which fits one of my ends but I'm going to get another made locally to fit the extra 2mm I need. Also needed to purchase extra punch to fit but was only £6 from BETD.
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=231&Name=Fox+Needle+Roller+Bearing ]BETD needle bearing Linky[/url]
Had the TFT ones fitted but don't like them, I used to have the BETD ones which are good but thought I would try the needle bearings as can get replacements locally for the same cost as a bush.
Posted : 08/03/2012 5:45 pm
I've always been slightly surprised they don't use Rose joints.
Posted : 08/03/2012 5:49 pm
Presumably enough flex in the frame to take out any bending across the pivot, combine with shock's ability to take out torsion.
Still, would make for stiffer frame/less shock wear.
Posted : 08/03/2012 5:53 pm
Agree
Posted : 08/03/2012 5:59 pm
IIRC the older spesh epics used to use something a bit like a rose joint for the seatstay-locationed shock.
Posted : 08/03/2012 6:39 pm
DT Swiss use something like a Rose joint.
Posted : 08/03/2012 6:48 pm
yer this type of spherical joint
Sealed
Unsealed
they are very robust
Posted : 09/03/2012 2:32 am
Fitted one to my Turner DW Flux - noticed no difference - save your money.
Posted : 09/03/2012 8:23 am
Get the poly ones from Kaesae's ebay store. 2 for about £4 job done 🙂
Posted : 09/03/2012 9:29 am
I would have thought a needle rooler would attract too much debris,especially if its lubed,& it will need to be,or can you get a sealed one ?,the DT SWISS idea looks good tho,like the rose joint, ceramics the way forward for less stiction,but would it be robust ehough,im not so sure, theres a reason why manufacturers use bushes,as clearly even on the top end bikes theyre still used! ..
Posted : 09/03/2012 9:42 am
yep they are cheap.
Posted : 09/03/2012 11:47 am
BETD hulu hoops DU bush replacements. Cheap Yes, good yes
Posted : 09/03/2012 11:58 am
ruscle - Member
Thanks but i think you misunderstood/I didn't explain well.
I had an RP23 which it worked perfectly on. I then bought a new frame with an RP23 included and tried to fit the bearing.
In the second RP23 it does not turn freely as the eyelet seems to be too small.
What I was saying is that believe RWC/Enduro now include a smaller bearing in their kits to cover this eventuality.
They also have rubber seals at the edges which i'm not sure the BETD ones do.
[url= http://forums.mtbr.com/9038956-post68.html ]See here for more info from Chris[/url]
As an aside, has anybody tried IGUS or Rulon J polymer bushings? They're meant to be very very good when used with thru-axle setup (i.e. not the Fox top hat setup). All the benefits of bushings, with low friction comparable to the bearings.
Posted : 09/03/2012 12:04 pm
 LoCo
IGUS bushings are pretty good, they're what the team riders use and last better than the standard DU bushes, I'd be slightly suspicious of bushes just refered to as Polymer as not all brands are the same, cheap ones being false economy and no better or worse than standard DU's. Only £1.50 each too, but are Igus ones 😉
Posted : 09/03/2012 12:15 pm
Not many shock companies actually run DU buhes these days loco, most run DP4's, do you mind me asking how you tell the difference between the two?
Retro what exactly is the difference between the shocks eyelet's?
Also the old epics 03/04 run spherical or rose joint bearings GE10c and GE15c
The 05 onwards epics run GE15cK1 which is a custom size and a pain in the ass to get hold of cheaply!
Posted : 09/03/2012 12:27 pm
Had a needle roller in the lower mount of my enduro, left it in the old shock as it wasn't very well sealed and required more maintenance to keep clean and corrosion free. Went back to BETD Hula Hoops.
Posted : 09/03/2012 12:38 pm
 LoCo
Kaesae, Du bush is a generic term, is 'eyelet bush' more suitable for you? have I done something to upset you? 😕
Posted : 09/03/2012 12:40 pm
I normally refer riders over to J Tech suspension for bushes
http://j-techsuspension.co.uk/pages/products/mount-kits.php
That said you might be able to find them cheaper else where
£13.99 per side supplied with 1x Igus JSI-0809-08 bush, are these the same inner bushes you sell LoCo?
Posted : 09/03/2012 12:47 pm
 LoCo
😆 Yes the Igus eyelet bushing are the same spec. Have a nice day kael 😉
Posted : 09/03/2012 12:49 pm
Hi Loco I thought that DU was a material that coats the inside of a steel bush and that DP4 was another material, DP4 last about twice as long as DU, so a DP4 bush will last half as long as a polimer one, or there about's.
It's my understanding that DU material is grey in colour and that DP4 is red in terms of it's lining, I might be wrong though 😀
Always good to learn new stuff, if you could help me understand the situation more that would be great.
Are your steel bushes red or grey?
Posted : 09/03/2012 12:54 pm
 LoCo
'Standard' 'eyelet bushings ( 😉 )' are 08DP08 spec orange inner coating as per Fox/Mojo aftermarket spec. (they appear to be manufactured by a company called GGB, but haven't looked into this.)
ID on these is tighter than the grey internal material and the Polymer ones although all are 08--08 spec so 1/2 X 1/2".
I don't fit anything but the Igus Polymer eyelet bushes now unless the shock has a specific 'issue'
I'm also looking at the HD/steel pin spacer kits atm, but so busy don't have the time atm (just having a sit and coffee now, before anyone says anything!)
Posted : 09/03/2012 1:03 pm
 sv
So you are asking another supplier questions that you perhaps should already know?
2x Polymer performance bushes.
These bushes are made up of a vastly superior and longer lasting material to DU and even more durable than the DP4 bushes I sell.
So can you confirm that your polymer bushings last longer than the metal bushings(with actual test results not just that you think they do)? Does your polymer have a trade name? Dark Star?
Posted : 09/03/2012 1:06 pm
 LoCo
Kaesae's quote of 4 times longer than a DU is about right, from our experience from the team riders use racing 24 hr races, getting Guiness World records (I love being able to say that, I'll put my willy away now 😯 ) and general stuff.
The Du v DP4 I'm not sure the DP4s are that much better a bit but not sure how much.
Right I have work to do so I'm going to turn the forum off !
Posted : 09/03/2012 1:11 pm
I'm having a curry 😀 very tasty
I think the 08__08 is the size and the inner is the material part 08DU08 08DP08
GGB is a manufacturer the first DU bushes I used about 3 years ago were from them. 08DU08
The Betd bushes will outlast most others as they are tighter in terms of fitting than tha IGUS bushes, they are also a nice design.
However you can get the Igus bushes cheaper, I would go with stainless steel reinfoced outer bushes and Igus inner bushes, then change them when they ware out.
Also be aware that the cream coloured polymer bushes suffer from transfer if you try and use them with aluminium outer bushes, this will cause excelerated ware, the grey coloured igus bushes mentioned above don't, but as loco pointed out they are a looser fitting bush.
Better get back to work my grub is almost finished
Posted : 09/03/2012 1:16 pm
No idea, but it must be a tiny difference.
I've only got cheapo ebay digital calipers and it's a difficult place to measure anyway.
Posted : 09/03/2012 1:17 pm
LoCo - Member
Kaesae's quote of 4 times longer than a DU is about right, from our experience from the team riders use racing 24 hr races, getting Guiness World records (I love being able to say that, I'll put my willy away now ) and general stuff.
LoCo you mentioned coffee not playing with yourself, I take it that's an STW code 😯
Posted : 09/03/2012 1:19 pm
sv - Member
Hello! SV
Goodbye! SV
Posted : 09/03/2012 1:22 pm
 LoCo
Posted : 09/03/2012 1:33 pm
 sv
Hello! SV
Goodbye! SV
Thought it might be a chance for you to confirm the quality of your polymer bushing material. As per Loco's post above:
Posted : 09/03/2012 2:14 pm
we use something called norglide at work
Posted : 09/03/2012 2:54 pm
WATCH OUT!!! thedevelopmentengineer those could be the cheap false economy ones.
It's not like we have ISO standards and other standards on stuff to ensure they are safe to use and of a certain quality.
LoCo just so I can make sure I don't by any of the cheapo ones, can you tell them apart from say the good quality ones you sell and also any names of shady companies selling them 😐 the Dastardly scoundrells!
I feel safe in saying my bushes are at least as good quality as LoCo's ones, then again maybe they're the false economy ones 😆 the mind boggles!
Posted : 09/03/2012 3:06 pm
 LoCo
Posted : 09/03/2012 3:42 pm
[i]the mind boggles! [/i]
indeed.
Posted : 09/03/2012 3:44 pm
 sv
Indeed.
Posted : 09/03/2012 3:51 pm
WOT? I'm trying to help out LoCo warn riders about the cheapo false economy bushes and also gain an insight into these bushes that I've never come across or even heard about.
Let's face it polymer bushes that last as long as DU ones 😯 , has anyone else any experience of those?
Better go shit to do, stainless steel outer bushes with igus inner bushes, best bet for durability in relation too cost and performance 💡
Posted : 09/03/2012 4:11 pm
you may be trying to help kaesae but I haven' got a clue what you're saying. It all starts out makign sense and then 😯 the smileys and random WARNING! 💡 WARNING! messages 😆 dilute it all. 😐
Posted : 09/03/2012 4:14 pm
what the hell who has a 22 meter frame? 😀
frame width of 22m x 8mm
Posted : 09/03/2012 4:18 pm
kaesae = out of his depth. Loco pisses on him for knowledge
Posted : 09/03/2012 9:53 pm
Posted : 10/03/2012 11:24 am
