Viewing 5 posts - 1 through 5 (of 5 total)
  • Need a bigger big ring
  • arcoolc
    I have a bog standard Deore 42/32/24 chainset on my bike, but as all the trails locally are intersected with road sections, I’d like to make the most of the tarmac bits and increase the gearing.
    What size big ring can I go up to without effecting front mech function?
    Ta
    geoffj
    *swoons*
    rusty90
    Real men have BIG rings !
    snaps
    44T defo
    46T possibly – but you’ll also need to check that your rear mech has the capacity for the extra chain length.
    Have you checked the small cog on your cassette? if its 12T, you could fit an 11T
    nick1962
    Possibly 48 as I run Deore 48,36,26 on my MTB commuter but you should check the Shimnao tech docs to see if your front mech is compatible.
    http://techdocs.shimano.com/techdocs/index.jsp
    Shimano front mechs need to drop at least 12 teeth from big to middle to function correctly too I think.It’s all in the tech docs.
The topic ‘Need a bigger big ring’ is closed to new replies.
