I’d recommend the Praxis Works conversion BB
I’ve had 4 Stumpjumper frames (1 aluminium, 3 carbon) and each of the 3 PF30 frames had a different tolerance (loose fit) on the inside diameter of the BB shell, which caused ongoing BB problems
Only the BB30 frame was within normal tolerance.
The Wheels BB would not stay tight and creaked. I tried grease as recommended, then fibre grip, did not work.
The Praxis BB would only stop creaking under power with a liberal application of Finish Line Fibre Grip (for carbon) on the BB shell interior before insertion – I used grease as normal on the metal/metal interface between the Praxis cups.
Perhaps an issue with the Praxis design is they use a PF30 nylon sleeve around the BB30 bottom bracket. I am sure with a “pure” PF30 design with the collet having a greater range of expansion they could accommodate a wider tolerance range.
You won’t know until you try to fit it, or have access to vernier calipers and can measure the shell ID, and check against the recommended tolerance (46mm +0/-0.05)
