Have some 2nd hand SIDs; lovely condition and only v light use. They're replacing my Pace forks.
However, it seems impossible to get the crown race squarely seated in the headset, so the forks won't sit square (so they end up rubbing on the top headset) and when tightened, grind. They look as though they sit higher at the back of the crown race.
This is still the case if I rotate the forks 180 degrees (and they rub at the same point and still look high at the back of the crown race) so it's not a bent steerer. I've tried 2 different headsets. Alternative forks fit fine and dandy. The LBS is mystified. The SIDs ran fine on the one previous bike they were on according to the owner.
Any suggestions of what to look at – much rather keep them than return them.
Ta
