Is the bike new? or under any gaurantee with the shop you bought it from? If so take it back and tell them you have a sticy piston in your front brake and ask if they could sort it for you. If it is not under warantee and you have a friendly local bike shop turn up with some biscuits and they may just sort it for you.
If you want to do it your self, idealy you will need a little brake fluid to wipe on pistons of the brakes and a small spaner
Remove the wheel from the bike, then remove the pads from the caliper, next thing you want to do is slide the spanner inbetween the pistons and press it against one pistons and pump the brake lever, this will push the opposite piston out BE CAREFULL NOT TO PUSH IT TOO FAR OUT. Smear a little of the brake flid on the piston and press it back in with the spanner. Repeate this process for both pistons a couple of times, push both pistons back ,clean everything with lots of water and put everything back together and it should sort the problem.
DO NOT GET ANY BRAKE FLUID ON THE PADS YOU WILL WRECK THEM.
