It wont take standard AA or AAA batteries. As Upling said, You will need 18650 ones and a charger and probably a UK plug adapter as well for the charger.
All in it will cost a bit more. If You want to run Your AA than get a Ultrafire C3 Q5. Uses 2 normal AA's, rechargeable fit fine and if You get the extension You can run the torch at 3xAA's (but only with rechargeable as they run lower voltage) and it spits out close to 200 lumen which is pretty good. The P7 is much much brighter but for general use the C3 is fine and it would make a good helmet light as it's pretty light.
