upto a point, you’re right:
– Spiral galaxies spin too fast, stars at the outer edges should fly off into deep space. They don’t, so galaxies are heavier than we can account for with stuff we can see. we don’t know what this ‘stuff’ is, so it’s been called dark matter. naming the problem, isn’t the same as understanding the problem. To a point, there’s a little bit of deux ex machina, or what-you-said, going on.
But, there is actual evidence for this-stuff-we’re-calling-dark-matter, beyond galaxies being seen to spin faster than Newton/Einstein can explain. There’s lots of different things we can see, that can’t be explained without a LOT of invisible mass.
Will developments in theoretical physics eventually make it disappear…?
we’re talking about dark matter because we’ve seen things that can’t be explained properly, those things won’t dissappear…
