I’m in the process of installing a pumped mixer shower. Previous set up in the house was mains cold piped direct to each outlet. Only the hot water system was supplied by the loft header tank.
I’m conscious that a pumped system could empty the header tank very quickly as both the hot and cold pumped feeds will draw from the same tank…
So, I’m planning to install a new 42 gal. tank in the loft space.
My questions are:
1. Replace existing tank? Seems like unnecessary additional work???
2. Retain existing tank as header for hot water system and add new tank as separate cold water feed for shower pump?
3. Add new tank, but with a connection to the old so that they operate as a single volume?
