Viewing 20 posts - 1 through 20 (of 20 total)
  • More camera advice
  • iamanobody
    What do you reckon to this http://www.trustedreviews.com/samsung-nx3000-review
    Only want to spend £200ish quid
    Have a galaxy S5 so should work with it
    Lenses seem cheapish
    For general “snapping” – nothing too pro!!
    stumpy01
    For the money it looks pretty good; could probably find better, could probably find worse. If it has the features you want and suits your budget, then give it a go.
    Might be worth getting it from a shop so you can have a play with it first to make sure you are happy with the feel of it and the menu system etc. before parting with your cash.
    Does it come with a flash or do you have to buy one separately. Might not be a deal breaker, but something to consider. And, as the flash isn’t integrated, is it likely to be a pain, taking it with you everywhere in case you need it??
    jimjam
    Counterpoint to that would be that on camera flash ruins most pictures and most modern cameras have such good low light performance and iso range they’re not really necessary. Off camera flash on the other hand can yield some nice results.
    Bikingcatastrophe
    If it really is only general snapping / point and shoot type photography I would go for the Panasonic Lumix TZ35. Brilliant little camera.
    stumpy01
    jimjam – Member
    Counterpoint to that would be fill flash to remove shadows on a sunny day?! 😆 Flash isn’t just about illuminating a dark scene. My compact has +/- 2 stops of flash exposure compensation, so it doesn’t have to drown out ambient light. Comes in very handy on bright, sunny days to avoid under-exposed faces.
    Perhaps this camera has a ‘dynamic range’ setting that would take care of that, but I find those settings often leave the image looking very flat.
    The OP mentioned
    so I doubt he’d be too bothered by off camera flash.
    jimjam
    stumpy01
    So if he is generally snapping on sunny days, and generally realises he needs some fill flash he’s generally going to pop up the flash, set it to fill mode, compensate exposure for flash….or is he just going to take a picture?
    Unless he lives somewhere particularly sunny I don’t see this being a big problem for “general snapping”.
    iamanobody
    Hopefully graduating form general snapping so the lumix is probs not the best. acn also get different lenses for the samsung
    stumpy01
    jimjam – Member
    You make it sound so long winded…..on my camera it’s a question of popping up the flash and that’s it. I generally have -0.7/-1.0 flash compensation dialled in all the time (easy to set-up in the settings menu) and popping the flash up automatically switches the camera to ‘fire the flash’. Nothing else required; although Nikon does flash stuff quite well, so maybe other cameras aren’t as simple. The longest bit is waiting for the flash to charge from the piddly battery.
    I’d rather have a flash on a take everywhere p&s than not. Others might not have the same view or requirement.
    stumpy01
    iamanobody – Member
    Have a look at how many lenses are available and how much they cost. I am not familiar with the Samsung lenses, so don’t know whether you’d regret getting a good initial deal once you started looking for different lenses and found there weren’t many and they are all expensive.
    Panasonic/Olympus use the same mounts for their mirrorless compacts so seems to offer the largest range of options and from what I have seen, they seem well priced.
    The Panasonic GF6 looks like a decent camera, but is £100 more than the one you link to.
    There are plenty of people on here with more experience of this type of camera who might be able to advise on other options.
    jimjam
    stumpy01
    I’d rather not, which is why I chimed in in the first place. Apart from off camera (very occasionally) I virtually never use flash at all, haven’t done so for many years. I like to work with whatever cards I’m dealt so to speak.
    iamanobody
    any more thoughts
    ampthill
    I’d say a good built in flash can be vary handy.
    peasant
    My £200 would go on this – https://outlet.sony.co.uk/shop/Interchangeable-lens-cameras-Alpha-/Compact-mirrorless-ILCE-/ILCE5000LB.CEC.A
    i have brought most of my stuff from here never had a problem
    iamanobody
    link no worky
    iamanobody
    but 50% too much
    tragically1969
    but 50% too much
    One day I will learn to read the full post before jumping in…….
    stumpy01
    Would you consider 2nd hand? You could get a decent 2nd hand SLR with lens for £200. Something like a Nikon D60 with kit lens on eBay seem to be going for £150.
    stumpy01
    London Camera Exchange have got a D60 with 18-55 VR lens for £150 and comes with 6 month warranty.
    http://www.lcegroup.co.uk/Used/Nikon-D60-+-18-55mm-VR_118355.html
    iamanobody
    Right – bought the samsung, get it tomorrow all being well. keep you posted
The topic ‘More camera advice’ is closed to new replies.
