I been srruggling to get my head around how the negative spring on the monarch plus debonair affects the spring rate.
I can visualise how the volume reducers affect the positive spring and the ramp up of rate at the end of the stroke, but how does a similar reduction in the negative spring affect the spring curve?
I think the thing thats confusing me is that the pressures are equalised at about 25% stroke, so a smaller negative spring volume should equal a higher pressure at full extension? Shouldn’t that make the small bump feel of the shock better?
Basically I’ve got these red rubber band thingies, should I put them in the negative spring to reduce volume?
