Andy – that was the exact issue I was having and it can be sorted, with a little patience and only adjusting one thing at a time. To get the plush feel on the small stuff it was blowing through on the drops, even 18″ ones! But after adding the four bands whilst still running the same pressure, rebound etc.. has sorted this for sure. Riding weight is about 185lbs in full kit and with water, I’m running 215psi in the shock, 28% sag and four bands it’s still plush over the smaller stuff but ramps up nice on the drops and jumps.
Benny – don’t drop the pressure when fitting the bands. Set the sag, rebound etc.. Then add bands to those settings, I’d always keep them the same even if your experimenting with adding even more bands. Then when you’ve solved the bottoming out, fettle with the rebound etc.. Because If you drop the pressure it will just sit to far into the stroke and you get the harsh/bottom out feel again. If you do feel the need to drop the pressure, do it in 5psi increments.
What worked for me-
Step one – Empty shock of air and start from scratch with adding 100psi, cycle through a few times to charge the small chamber, as per Rockshock site.
Step two – Set sag at 28% whilst in full kit inc water by adding more air
Step three – Note pressure, let air out, remove can, add 2 bands
Step four – Repeat step one, top up air to whatever it was that you noted down.
Step five – Go ride. If it still seems to bottom out, repeat step 1, add two more bands then add air, again to whatever it was you noted down and go ride some more.
Repeat the above adding or removing bands each time but keeping the same air pressure till your happy.
Took me about four rides to find the sweet spot and well worth the hassle imo.
HTH
Carlos
