A few years back I made a log splitter. It was a bit of a scrapheap challenge but it worked well, then even better when I replaced the main vertical beam with a larger I beam.
I had to use a portable hydraulic power pack to work it.
https://picasaweb.google.com/113038090087066024057/20110226LogSplitter
I’ve got a friend that has a JCB 8015 mini digger.
We are keen to try to build a log splitter that can mount to where the bucket is fitted, and to use its hydraulics to power the splitter.
Has anyone seen or built one?
There are a couple of YouTube clips which show a type which uses the splitter to pick up a log and then split it. That’s not what I’m after. We’d like to build a static type similar to mine that be simply mounted to the digger.
