Micro SD card probl...
[Closed] Micro SD card problem
[#2321668]
My HTC HD2 has a micro SD card, when I want to download images to my PC I simply put the micro card into an adapter. I then put it in the slot and choose one of the options that appear, usually 'download to file'?
However my PC now doesn't want to recognise any images and I don't get the full set of download options, only three now and they're music orientated i.e play with a, b or c.
Any idea what's happening?
The images are definitely on the micro card as they wont appear on the phone with the card removed.
Posted : 29/12/2010 7:44 pm
Can you leave the card in the phone and explore via Activesync?
That's what I do with mine, it avoids having to take the battery cover off too.
Posted : 29/12/2010 8:42 pm
Bluetooth them from your phone to your PC?
Email them to your PC?
USB lead and Active Sync is the way I do it though.
Posted : 29/12/2010 9:40 pm
Ta Activesync sounds the ticket.
Posted : 29/12/2010 10:47 pm
Once you've recovered the data, I'd format the card. Hopefully that should fix it. If not, consider replacing it.
Posted : 30/12/2010 1:35 am
