Viewing 8 posts - 1 through 8 (of 8 total)
  • Medium or long cage
  • jsync
    Hi,
    I plan to run 24/38 with a 36/11, do I need a medium or long cage XT mech?
    TIA
    Kev
    tmb467
    Long cage according to shimano but you’ll probably get away with medium if you’re careful
    It’s a 39t spread so get chain length ok in big/big and don’t go small/small for maximum security
    tmb467
    Meant to post this too
    Advice
    jsync
    Thanks for the link above, sounds like 39T on a 150mm FS will be too much for a medium, will go long to be on the safe side.
    Thanks,
    tang
    I run a medium no probs on a 26/38 11-36
    jsync
    Tang,
    Do you think that 24/38 with a 36/11 would be ok? 2 more teeth…
    Thanks
    Twin
    I run 24/38 with 36/11 on a medium cage mech. No problems ever.
    jsync
    Is that using all cog combinations?
The topic ‘Medium or long cage’ is closed to new replies.
