Hydraulic clutches are self adjusting so the clutch bite point will not change like a cable clutch would do as the plate wears.
Some makes just have real high bite points. Wife’s corsa is low… Volvo is a bit higher. My honda crv is very high but having driven loads of hondas they all seem to have high bite points (apparently the Japanese like them that way).
Easy test is to drive up a hill in high gear (4/5th) if revs rise but engine speed doesn’t clutch gone.
Also find a bit of space…. While stationary shove into 4th and try pull off. If it stalls clutch good.
As said above…. You really would have to do some special clutch control (or lack of) to burn out friction material in 22k. But I am sure my wife given the chance would manage it.
