Mechanical bodge he...
[Closed] Mechanical bodge help required (X-fusion dropper)
[#3115884]
I need to lube the seal on my X fusion dropper post , USA tech dept says its Ok to take it off & grease, but I cant get any purchase to unscrew it. Its about 30mm dia. and a smooth anodized surface. Have tried a pipe wrench and tyre bodge but no shifty. Any ideas of using general things around the garage ? Don’t really want to use the vice for fear of crushing.
It’s the red bit-
Posted : 05/09/2011 2:12 pm
Vice with soft jaws?
Posted : 05/09/2011 2:13 pm
ONe of those things for old folks to open jam jars?
Drill a small hole below and grease gun?
Ask the distributors how it should be done?
Posted : 05/09/2011 2:19 pm
+1 for al's suggestion, strap wrench should see it off ok.
Not a left hand thread is it? Probably not, but it's worth checking!
Posted : 05/09/2011 2:20 pm
Boa wrench?
Or cut Vs in 2 blocks of wood and use those between the vice and shaft
Posted : 05/09/2011 2:21 pm
a small memac will shift that - if you have one in your shed your a better man than i 😉
Posted : 05/09/2011 2:32 pm
What type of places sell strap wrenches, DIY / OAP shops ?
Posted : 05/09/2011 2:35 pm
B&Q
Posted : 05/09/2011 2:36 pm
+1 for boa wrench - most DIY or motor mechanics shops will have them inc Halfrauds as you can use them for taking oil filters off 🙂
Posted : 05/09/2011 2:44 pm
I can ride to B&Q on the way home 💡
Posted : 05/09/2011 2:46 pm
Any luck? I need to do the seals on mine - also, did you get the red collar separately or with the post? Bling!
Posted : 06/09/2011 11:56 am
Also you can use them for opening stubborn air cans on rearshocks.
Posted : 06/09/2011 12:47 pm
