edward2000 – Member
I blame your username
very good 😆
LAT – haven’t got around to that, but ive put another tyre on this rim and no wobble
SSSTU – possibly, it is quite worn, but still just 2 days before I swapped it over it was fine on the other rim
ONZADOG – yep double checked that, the line runs completely in line all the way around on the rim, theres no hint of it sinking further down at one point of the tyre, ive reinflated, rejigged its position on the rim etc
the wobble is actually causing the disc rotor to move slightly too (assume the rotating weight is flexing side to side so its catching on every rotation….and yep when I put a different tyre on the disc doesn’t catch at all, so its all in the tyre..typically no bloody shorty stock anywhere in the UK
