Viewing 11 posts - 1 through 11 (of 11 total)
  • Mavic Crossmax SL Buzzing noise?
  • Nezbo
    I was on a ride today and i got a buzzing noise from my rear wheel.
    I have been doing some searching around and i think this is not a uncomon problem
    http://www.socaltrailriders.org/forum/workshop/17308-servicing-mavic-crossmax-sl-hubs-2006-a.html
    Has any one on STW had the same problem?
    There is a guy on the above link that says that he has come up with a solution that replaces the plastic bushes with burings, his websire dont work though 🙁 has any one else done this?
    onandon
    take the freehub off and give it a clean and re-lube.
    its a 15min job its you take it reeeeeeeeealy easy.
    flamejob
    You may need to replace the bearings in the rear hub. It worked for a friend, though Mavic did it very cheaply at an event in France.
    It took us ages to find out what was causing it; sounds like a sporadic stick against the tyre eh?
    Nezbo
    on and on I have done that but there is still a bit of play 🙁 so i think the bush in the freehub is a bit worne, i know they are only £25ish on CRC.
    here is the idea on ebay Bearings on freehub insted of bush I know it is not a shimano but that is the idea, only if i can get the same thing in shimano…
    Nezbo
    flamejob that is the exact sound. the bearings are fine, so i guess i will just buy a new freehub 🙁
    westkipper
    Another troubleshooting possiblity-
    I have had rear Ksyriums which developed a buzzing sound that no amount of fiddling with the internals could alter,
    Then , after much stupidity, I had the idea to try the wheel with a different skewer….. BINGO! The various bits of the skewer were indeed rattling against each other.
    I think Mavic use a similar skewer on the MTB wheels, so it might be worth a try first.
    Or, having just read the posts above, maybe not!
    Nezbo
    west kipper i have shanged my skewers a while ago cos i didnt like the rattleyness of them, so defo not that cheers anyway 🙂
    westkipper
    Nae bother!, Interestingly I've also had strange noises from Ksyrium freehubs, but more like a metallic scraping sound- went away with time.
    Sum
    I had a similar noise coming from my Mavic Crossmax SL rear wheel. Looking down I could tell that it was the freehub binding because the chain went slack. Removing the freehub and cleaning/re-lubing it solved the problem.
    Top.Dog
    i've had the same problem. cleaning solved the problem, but it soon came back. Does the buzzing get faster when you back-pedal?
    Nezbo
    Scheleschirche not tried back pedaling, but it stops when i pedal forward…
The topic ‘Mavic Crossmax SL Buzzing noise?’ is closed to new replies.
