Marzocchi Z1 BAMs
[Closed] Marzocchi Z1 BAMs
[#1580987]
Yes the original 1997 orange one. Disc tabs on both legs, nice! But I only want to run a disc on the "normal" side. Which brake caliper/mount?
Anyone able to help?
Posted : 06/05/2010 6:28 pm
Yep, a great fork indeed.
The problem you will have is that those were designed with their own 'standard' mount which was designed for a specific brake - can't remember which off the top of my head - a Hope caliper No. 5 maybe from a C2? The bolt spacing is different.
Anyhow, there is a way around this. I made up set of adapter plates to run IS brakes. My XT 4 pots to be precise. I think I still have it? If not I could be persuaded to make up another (I still have the drawings) for some beer tokens...
Posted : 06/05/2010 6:43 pm
 Olly
i have a pair of Z1 bams in orange, (except some vandal hammerited them black) with an IS disk tab on the left leg only.
the bridge brace thing is cracked, and a stantion is scratched a bit so they leak, but OTHER than THAT they are fine.
any use to you?
(they are cluttering up my life at the moment)
Posted : 06/05/2010 6:45 pm
Zedsdead. So your designed adapter will allow the said fork to take an IS brake caliper? I would be able to fit either a Hope C2 or a Hayes nine with 185mm rotors
If so yes please I`ll take one. How much beer would you be considering(pints 😉 )
Posted : 07/05/2010 6:26 pm
Correct. I'll go double check and see if I still have it. I'll also measure it to confirm but I am certain that it was indeed 185mm rotors I used...
I'm studying (hence the delay in reply) for exams this Monday and Tuesday but I'll have a rummage at some point and get back to you ASAP.
Posted : 08/05/2010 2:38 pm
Hi t-p 26
I found the adaptor. Now, I can't remember if I used a 185 rotor or a 160 rotor? I have an excellent condition Shimano 160 rotor wihch makes me think it might have been that which I used?
Anyhow, if you're interested then let me know.
Posted : 09/05/2010 1:20 pm
YGM
Posted : 11/05/2010 9:57 pm
