it says 195mm of oil, where is this measured from/to???
I think you mean ml rather than mm (unless marz have written in in the usual poor english)
It is the volume of oil to be put in the leg rather than an oil height. An oil height would be something like 50mm or 80mm rather than a large measurement such as 195mm on a 160mm fork.
My 55TST2 had an oil height of 30mm below the top of the leg from the factory, (with the spring removed and the fork fully compressed) and I think that is too much oil. I have dropped the oil level to 50mm below the top of the leg, but not ridden it yet to check.
If there is too much oil in the spring leg the air in the space above the oil will compress too quickly and stop the fork using all its travel.
