I’ve currently got both the 350ncr & Pikes. I’ve also owned loads of decent forks including 55rc3ti, 36rc2 & Bos Deville, to name but a few.
In terms of all round performance as both a big hitting Alpine descent & all round UK trail fork, I found the Bos to be the best compromise of weight, small bump sensitivity, big hit support & recovery. For hard hitting constant downhill, repeated square edged hit capability the 55 was buttery smooth & composed.
This year in the Alps, whilst using the Pike, I experienced arm pump the like of which I haven’t had for all the years using Marz or Bos.
Now, the 350ncr; it seems to have a very linear air spring that feels coil like, but isn’t as good as the 55 on small bumps. Feels like a tad more breakaway force is required. That said, this seems to be either getting less so, or I’m getting more used to it. Fast bumpy/rough descents feel very composed but unfortunately I can’t yet comment or compare against the Pikes regarding my arm pump. It’s the low speed damping & mid travel support that’s really impressive. Once soaked in via the compression & damping controls they’re pretty amazing. Sooo controlled.
My biggest criticism is they’re not quite as nicely finished as all the others . E.g. On getting them the stickers were half peeling off, & the compression knob feels a bit loose. But overall I’m very impressed.
