deadkenny – Member
Air – always measure the sag yourself. Set at 30%-ish and see how it feels. Adjust between 20 and 30 as you see fit. Forget what the manufacturer says generally, although it may be a starting point.
Everything else is personal preference and riding style. Guides may tell you what settings are better for what, but it’s really down to playing around. Unless you buy or service from TF Tuned, give them (truthfully) your details and preferences, and then what they tell you may be fairly spot on. At least that’s what I found with my CCDB shock. Though to be fair CC do a lot of work with publishing base tunes for specific bikes and have a forum to discuss tuning. Even then you can use their extensive guide to tweak it for your riding and terrain.
Yeah thats what I’ve found, well I’ll be sending my pikes off to TF Tuned before I do Ard’Rock so they will be hopefully set up properly
