"bit of muck off"
No, avoid muck off or any bike cleaner like it
If there was one thing that came out of that 'fox failures' thread from a while back it was that the stantion wear problem (on RS as well) was down to using muck off
Cleaning and relubing* the drivetrain will help it last longer
*Relubing mid ride if the drivetrain becomes dry, especially on wetter/muddier rides helps a lot too (not just for longevity, but for efficiency too)
Checking the chain wear with a chain wear checker tool, you should be able to change your chain 'early' a couple of times and save a lot of wear on the chainrings/casette (ie before the whole lot is worn out and the chain is snapping every ride). Look up an old thread for more info on that
Clean the stantions/seals of the suspension will help (Specialized for one don't want you to use one of those neoprene/rubber shock covers btw)
Check the manuals for the forks/shock for the various* service intervals, even if you don't intend to do any of them, at least you'll have an idea as to wether its still within the service interval if it goes wrong under warranty
(*checking and setting the sag and rebound every ride is a bit OTT imo)
If the wheels have cup and cone (mostly shimano hubs) bearings (not cartridge bearings) then its worth adding more grease in from new to make them last longer as they don't come with loads and the seals tend to be alright at keeping dirt out
