Viewing 16 posts - 1 through 16 (of 16 total)
  • Magnetic nipple inserts
  • Onzadog
    I know Campagnolo/Fulcrum nipples are guided through the rim with a magnet and a magnetic insert.
    What I’m after is knowing if the Campagnolo/Fulcrum insert fits a standart 2mm nipple or if anyone makes similar for a 2mm nipple. The stainless spokes I have are only very mildly magnetic so looking for something a bit stronger.
    bearnecessities
    *Disappointed*
    matt_outandabout
    Onzadog
    I enjoy the comedy responses but useful ones are also very welcome.
    hammyuk
    “gets the popcorn and awaits mrsfry…..”
    gofasterstripes
    Sounds like a way to build a covert ebike motor to me.
    Are you getting into cyclocross?
    Onzadog
    I just want to feed some spokes into a sealed rim. No magnets will remain and no motors will be involved.
    frogstomp
    Unior Nipple Assembly Tool? Uses a spring rather than magnet to hold onto the nipple..
    MTB-Rob
    the Fulcrum mag kit will not fit into a normal nipple,
    the threaded part is about 4mm in dia.
    What about finding a steel spoke and cutting it down so a bit sticks out of the nipple, might need a small magnet to fit so it powerfull enough to “picked up” by the magnet outside the rim.
    Onzadog
    Thank MTB Rob, I had considered that. Now, can I find a ye olde steel spoke?
    Seems Campag/Fulcrum do a number of sizes of that tool. Wasn’t sure if any of the fitted a normal spoke nipple.
    gofasterstripes
    Pretty sure “stainless” spokes are still magnetic.
    Onzadog
    Only slightly. The neodymium magnets I had to wrestle from the side of TH fridge only gently pull on a stainless spoke. Not enough really.
    gofasterstripes
    Oh well.
    njee20
    That’s just for a normal rim – I think the OP is after something he can use to drop a nipple into the valve hole on a UST-style rim, then walk it round to the spoke hole.
    ghostlymachine
    Use a piece of cotton thread and a vacuum cleaner……
    Onzadog
    Vacuum cleaner? Does that work?
The topic ‘Magnetic nipple inserts’ is closed to new replies.
