'Magic Gear�...
[Closed] 'Magic Gear' Ive only gone and done it, I think........
[#4008052]
OK I have an old vertical drop-out 456 and have managed to install an Afine 8 Hub gear without a tensioner. It worked because the Alfine spindle has flats pre machined on it which when installed with a 36t front and 18t rear gave perfect chain tension.
I used an old pre-stretched track chain, so hoping it wont grow much.
Rode it last night and loved it, just perfect but..
Im feeling all smug as Im not normally too good at stuff like this.
how long will it last?
Any opinions?
Posted : 25/05/2012 11:40 am
chains "wear" longer rather than strectch, so it will happen (slowly in summer, quickly in winter IME)
however, they're are also pretty cheap so you're pretty much laughing still
Posted : 25/05/2012 11:51 am
Hope it lasts ages fir you. Chain tensioners spoil the "look" of an Alfine or single speed bike.
Posted : 25/05/2012 12:20 pm
Coolhand.
I agree, I wouldnt have built it if I had to have a tensioner. Just looks wrong.
Weirdest bit is (to a non S/S rider) the noise, or rather lack of. No Mech or chain slapping away, not even a noise from fre-hub.
Love it, been out again today. Love it even more.
Posted : 25/05/2012 12:36 pm
I ran 36-16 singlespeed on my 456 for ages without any problems from wear. Its a great feeling!
Posted : 25/05/2012 12:43 pm
well done! I once did it on my kona caldera with a kmc kool and one halflink for ss.. was sexy
Posted : 25/05/2012 12:45 pm
Congrats. If you buy a half link, then you may be able to fit this after it has stretched and it'll work its magic again.
Posted : 25/05/2012 12:52 pm
Not feeling so good now.
I thought this 'Mythical Magic' was almost impossible.
Well chuffed with the way it works though.
Hub gears are the future.!
'Hoorah the wicked Mech is dead'
Posted : 25/05/2012 2:09 pm
I have it running on two bikes. Never had an issue with it on the commuter but even with a halflink I still occasionally drop the chain on my mountain bike
Posted : 25/05/2012 2:10 pm
naaa, [i]bottom bracket[/i] gears are the future 😉
Posted : 25/05/2012 2:42 pm
magic gears are a compromise and always will be. I would just get a frame with horizontal or track dropouts.
Posted : 25/05/2012 3:03 pm
Agree Horizontal drop-outs are the answer but as far as I know 456 steel frame is not available with that.
Tried Argos cycles and Dave Hinde but both couldnt or wouldnt give me a quote for drop-out alteration.
Posted : 25/05/2012 3:20 pm
It may be a copmrimise but it looks neater and given how cheap chains are the "chain growth" does not worry me. Also you chain "grows" with a tensioner also but as it takes up the slack you do not notice. Ultimatley chains should be changed at 0.75% to preserve chainrings and cogs. I have found 0.75% wear is when a magic gear starts to give slipping problems so I have two reaosns to change the chain.
Just Googled 'half links'. I like them.
Is it still magic though?
Posted : 25/05/2012 4:09 pm
