Not worth it.
Just run 2 tokens or maybe 3 depending on how aggressive you’re feeling and how heavy you still are. Lyriks dive quite a lot in a linear fashion without tokens.
If anything get the german sounding new air shaft fitted from tf or similar as that’ll keep the fork more in its mid stroke and help with the diving whilst keeping a slightly lower air pressure to allow more suppleness.
Short answer – dont bother I rode everything on my capra all summer with lyriks with no dramas – they feel a bit rougher than fox40s but track well and keep you composed (if they aint too soft). No weird arm pump or anything like that.
Give us a shout if you’re out. It’ll be good to ride together again!
Alex
*Edit – also not sure what your Pila logic was – thats well more rough on the hands with all the hidden rocks under the golden pow.. and that rooty descent to Aosta is an arm killer.
*Edit 2 – you cant.. it only fits for 160mm lyriks.. i’d say 160 would ride even better than 170mm with this kit:
https://www.tftuned.com/luftkappe-upgraded-piston-kit-for-solo-air-pike-yari-lyrik/p3288
You could also fit the MRP which may actually have more on trail use.. essentially the same as adding tokens but you can do it on the fly externally with a twist of the hand.. that way you can soften and firm up the forks as you go though out the day.. track dependant . Might have a bit more real world mileage with that.
Or just dont bother – lyriks are fine
