Viewing 4 posts - 1 through 4 (of 4 total)
  • Lottery Funded projects, where to find our more info?
  • Lazgoat
    Any ideas how the Lottery funds projects or where to find out some detailed info?
    Thanks!
    matt_outandabout
    The lottery site has some information of all the projects they have funded on.
    The amount of reporting we do for them means that they should have loads of details…
    superleggero
    If you are thinking of applying for funding, what type of project do you need funding for (Sport, Arts Charitable etc), is it a revenue project, will you be building facilities of some sort, and how much do you need? Also where you are in the UK may have some bearing on which Lottery distributor you should approach. Lottery funding for sports projects for example is though each of the home country sports councils (England, Wales, Scotland and NI each have theor own).
    Funding for charitable purposes, health, education and the environment is through the Big Lottery Fund which is UK wide and distributes 40% of the money available – info here: https://www.biglotteryfund.org.uk/funding#
    Whatever you apply for read the application criteria very closely and make sure you meet them. Try to talk to someone at the Lottery distributor you are applying to before you make your application. Can save a lot of time and that advice can help in giving your application the best chance.
    BillMC
    Look carefully at their requirements for eligible organisations for applications. They are very rigorous about which type of partnership etc etc. It is easy to spend a lot of time on this and fall at the first bureaucratic hurdle.
The topic ‘Lottery Funded projects, where to find our more info?’ is closed to new replies.
