Have been doing some pondering and trying to work out the best way to approach my streaming setup.
I have a NAIM Uniti and also a UnitiQute in diff rooms obviously. My house has Cat 5e through it so there is a network as well as wireless. Currently i have just been streaming using Allegro Media Server from my iMac and it just uses the iTunes library.
I did some tests using lossless FLAC and WAV and jeeesus its quite different to even the HQ in iTunes. I mean, audibly different, better bytes probably 🙄
So what i want to do is have a lossless library, i figure storage is cheap. I can use Asset as the uPNP player but the ripper doesn;t work under Crossover on the Mac, well it does but it can;t see the CD and never will apparently.
So that would mean i either have to build a windows based media server with USB attached storage , i could buy a UnitiServe (I get Naim at cost but even so …), rip everything to a USB drive(s) using a windows machine then run Asset under Crossover or ?????
Anyone doing anything similar ?
I know, what a terrible complicated life i lead if this is my only concern 😆
