Hello all,
Had a log burner (contura pricey job) install done last year; ended up with getting the heats engineer to rig the whole thing up to prevent any problems with building control.
I wasn’t home much last winter, but used it on a few occasions and felt dizzy a couple of times using it; the Carbon Monoxide sensor went off a couple of times. But to cut a long story short, I suspected my gas cooker (the house was then condemned…the manufacturer came out along with the utility company) and they tested the cooker… and found no problems or carbon monoxide present (…although of course wood burner wasn’t on) …
Subsequently I bought a carbon monoxide meter (a UNI-T UT337A) and for the first time yesterday threw a log on the fire…I stuck the meter on, and sat it near the fire and within about 20 minutes my girlfriend said that she felt light headed!!! The meter reads 000ppm and the detector alarm in the room doesn’t go off!
So I opened all the windows…and I’ve come on singletrackworld for some advice… I’ll be calling the HETAS engineer in the morning otherwise, but can’t really think what the problem might be?! The room has an open doorway and the stove is small for the room (less than 5kw or whatever the requirement is).
I have tried different kinds of logs, and doubt that I’m burning anything noxious. The glass stays clean and the draw seems to be good (we went for a bigger flu liner than required)
Is there anything I SHOULD CHECK or can test before calling the engineer? I’m starting fires with the vents fully open and sometimes shutting down as the burn gets better, with the bottom vent flicked to logs (as opposed to solid fuel)…
