Viewing 4 posts - 1 through 4 (of 4 total)
  • Loctite in BB removal?
  • Slacks
    I’m watching a Cannondale frame on ebay at the moment. The seller states the following:
    “The design of this frame comes with the bb30 bottom bracket. I have had a english threaded reducer fitted so I could use my higher end cranks than what the bike came with.
    The reducer is loctited in so can be removed by any good cycle shop, I have the original bearings as well so you have a choice on what system to use.”
    Does this sound like thread lock? How easy would it be to remove?
    I’ve asked the seller if he can tell me what type/colour the Loctite is.
    dmoffitt90
    There is loctite remover readily available from Loctite/henkel so shouldn’t be a problem
    uplink
    Does the reducer need a special tool to get it out?
    Slacks
    I have no idea about the tool. I’ll consult Google.
    When I looked up Loctite removal it seemed to suggest heating up the object. Not ideal.
The topic ‘Loctite in BB removal?’ is closed to new replies.
