Laying a gravel pat...
[Closed] Laying a gravel path - help please!
[#1740504]
I need to put a gravel path down in the garden.
I plan to put black anti-weed material down first, then a material to sit the slabs on.
Please can someone remind me what material I need to bed the slabs into?
Is it coarse sand?
(The path is going to be very low footfall, and needs to be done on the cheap)
Thanks.
Posted : 25/06/2010 2:52 pm
Sharp sand IIR (but I might be wrong - haven't done one for nearly 2 years). Get a decent weed-proof membrane or you'll be forever plucking them out. I take it you're creating a gravel path with slabs here and there?
Posted : 25/06/2010 3:06 pm
Yes that's it, a gravel path with the odd slab.
Cheers.
Posted : 25/06/2010 3:44 pm
Old carpet is good weed protection provide you clean it with soap first.
Sharp sand to bed in slabs.
Posted : 25/06/2010 3:51 pm
smile nicely at your postman , Royal Mail sacks make an excellent heavy duty weed membrane.
alternatively get some of this , http://www.toolstation.com/shop/Ground+Maintenance/Landscape+Fabric/d250/sd3225 .
That stuff they sell at B&Q type places is next to useless.
Posted : 25/06/2010 3:54 pm
I always use drymix for bedding in slabs. 8:1 sand cement. Goes hard when it drys and stops the sand being washed away in heavy rain
Posted : 25/06/2010 3:59 pm
Drymix sounds interesting, can I get it ready mixed?
Posted : 25/06/2010 4:34 pm
lay lots of salt on the ground then a carpet or membrane, more salt and then sand
Posted : 25/06/2010 4:45 pm
Doubt it. Just get a bag of cement from wherever you get the sharp sand. Sand into wheelbarrow, cement on top, mix in wheelbarrow with spade/shovel
Posted : 25/06/2010 5:43 pm
Just laid a lovely patio, and drymix is perfect. You must use sharp sand though. I did hire a cement mixer due to the amount (1.5 tonnes!!).
Just mix it up in a wheelbarow. You'll only need it under the slabs.
Posted : 25/06/2010 5:53 pm
 jond
If it's just onto sand, has to be sharp sand, if onto concrete then 8:1 sharp sand:cement (just been using the latter to extend some slabs under a shed, the recommendation I found was >40mm thick)
Posted : 25/06/2010 6:40 pm
you can but dry mix but why pay those prices, its not difficult to put a few shovels of sand in a wheelbarrow then a shovel of cement then a few shovels of sand.... I would however spray with weedkiller first of all (the ground not the dry mix!!) If you are sure that its going to stay as a path and not be planted again in the next few years then buy the strongest you can get, one that lasts 5 years, even with your anti-weed material they will still come through, maybe not this year, but they will
Posted : 25/06/2010 7:51 pm
Posted : 25/06/2010 10:16 pm
