- This topic has 68 replies, 27 voices, and was last updated 7 years ago by glasgowdan.
lawnmower (petrol) engine – fix it or buy new?
sharkbaitFree Member
Punky, you do know we’re going to need a video of the running engine once you’ve completed this might task 😛
sadexpunkFull Memberi think i can do that, watch this space 🙂 at work from tomorrow for 5 days so will hopefully have it serviced and back together on wednesday.
EDIT: jus wundrin….. imgur for hosting photos, does it do vids too? or will i have to upload something to youtube say?
bigdaddyFull MemberYay, thanks to this awesome thread, I’ve just bit the bullet and had a play with mine, which I haven’t serviced at all for years – it’s now got a cleaned up spark plug, air filter and oil change. Runs lovely and a warm sense of satisfaction that it was easier than I thought and I didn’t break it! Cheers guys – you lot are always helpful for absolutely everything!!
RustyNissanPrairieFull MemberNot sure if lawnmower’s are ripcord/ pullstart (I’m guessing they are) but don’t just go flalling away on the cord – SLOWLY pull and turn the engine over till at TDC (maximum resistance on the cord), let the cord go back in, slowly take the slack out then give it a good pull. Repeat until started.
Pull cords will thank you.glasgowdanFree MemberCouldn’t be bothered with my old mower any more so I bought a new one 🙂
Quite looking forward to it actually. New one is £600 instead of previous £1300 and before that £1800. So I only want it to last a year. New one is 35kg instead of 70kg. The only thing is it doesn’t have a BBC but I’ll get by with that.
🙂 Handy few features such as a fuel cap with a clutch so you can’t overtighten it, and a nice firm deck height adjust with only 5 positions.
sadexpunkFull MemberNew one is £600 instead of previous £1300 and before that £1800. So I only want it to last a year.
trail_ratFree MemberHave they put fibreglass decks on a decent cutting lawnmower ?
We used to get through a 1300quid honda every 3 years due to Ali deck rot depsite washing the grass off the undersife regularly.
Also had an fibreglass etasia . It was a great mower if you were doing acres but was on wheels and was shit for doing gardens.
And we had a hayter for doing the walled garden and tennis courts.
CougarFull MemberAre you wearing a suitable shirt while working on the mower?
Is that a young James May?
cranberryFree MemberTrail_rat – how about a Stiga ?
My mum has an acre and a half site, mix of paddock and lawn and a 2nd hand Stiga Park is excellent and seems very well made.
trail_ratFree MemberI’m no longer in that industry so don’t need one now but a quick look at stigas shows their self propelled unit has an alu steel deck same as the Honda’s.
HounsFull MemberThe spring will be under your fridge. Sure someone hasn’t been using 2 stroke in it :p
Ro5eyFree MemberThe mower man is picking mine up this morning…. He’s basically going to do what you guys have suggested and sharpen/balance the blade for £110.
So well done to the gents who’ve save themselves a pretty penny.
Next time I’ll have a go myself (I hadn’t read this thread before arrange for the service)… but having only ever replaced the spark plug once in 9 years I reckon I can “afford” to let someone who really knows what they are doing give it some loving care to my Hayter Sprint 41.
But I am going to have a go at the strimmer…. It’s a 4 stoke so I’m guessing the principles are the same…. It’s ticking over ok but cuts out when you rev it up.
trail_ratFree Memberfor the strimmer my first check would be a leaky fuel pipe especially if you have left it sitting with fuel in.
ironically the fuel pipes on most hand power tools – strimmer-hedge cutter-blower – chainsaw use a rubber pipe from the tank to the carb that degrades when fuels left in and goes brittle. picks up a hole – idles fine but when you stick it on throttle the sucking of fuel increases and it sucks in air through the hole.
Used to keep a roll of it in the van for when we got the symptoms you describe as it wasnt really practical for us to drain all tools after each use.
sadexpunkFull Memberupdate! failure….. 😥
its maybe even worse than before
[video]https://vimeo.com/208350554[/video]
couple of things i wasnt sure of tho, so alls not lost yet. firstly, the spark plug, havent got any feelers so just plopped it in as new and hoped for the best. not really sure its a spark plug problem tho.
secondly the springs. heres a couple of short vids of how ive got the springs. not sure theyre right tho. dont understand all that ‘governor spring’ sh1te and how it all works. i moved that little lever on the left a bit and got really high revs, so then moved it a bit to the left and got the low revs in the first vid, but it keeps dying on me still.couple of times it died after a second or two anyway and wouldnt start again, then i left it and it started again next time, but still no good.
[video]https://vimeo.com/208350829[/video]
[video]https://vimeo.com/208350154[/video]
im sure i put the carb/gasket/diaphragm back together ok, and a new air filter rubbed in oil.
anyone care to hazard a guess? 😕
thanks
sharkbaitFree MemberSounds like it may be a fuel supply issue.
There’s no smoke so I’m presuming the compression is good and rings are not worn.
HounsFull MemberShouldn’t you have a cable running from lever on ‘handlebar’ to the black lever attached to the spring in that last vid?
sadexpunkFull MemberShouldn’t you have a cable running from lever on ‘handlebar’ to the black lever attached to the spring in that last vid?
just been out to look, the handlebar cable goes to a little lever at the back of the engine which cuts it off when released, so that all looks fine and working as it should.
tillydogFree MemberThe springs look roughly right, but there’s something wrong as the linkages aren’t moving freely – the throttle (turny thing in the middle) should spring back fully clockwise, and it should take very little pressure on the linkage to close it (turn it anti-clockwise). Everything should move like a Swiss watch – it relies on the breeze from the cooling fan to close the throttle when the engine is up to speed and the springs to open it again under load. Be gentle with them! The carb is probably OK.
The link by your finger isn’t in its hole properly, and is probably binding:
Disconnect this and check that the arm near your finger (connected to the vane inside the cowling) is also moving very freely – may need a bit of a clean up. Provided it is, connect the linkage properly and check that the whole thing moves freely.
Have a look at this for inspiration:
[video]https://www.youtube.com/watch?v=NDMR–XhC8g[/video]
Edit: You may need to take the carb off again to get that linkage in right – don’t force it!
sadexpunkFull MemberThe link by your finger isn’t in its hole properly, and is probably binding:
youre right, it didnt want to go in so i forced it a bit as it seemed the only way i could see that these springs connect.
thats just it, im not sure how it connects.
thanks, found that with google and thats the exact video ive been looking at to try and see how they connect, freeze framing when it does a close up. still cant fathom it, cant see how else it can connect other than how ive done it, even tho it didnt want to…..
do you think these springs are they key to solving this issue?
EDIT: just watched the vid again and see what you mean about the doobery springing back clockwise, need to try and work out why mine isnt. done a close up of it again and looks the same as mine :-/
tillydogFree MemberI think the springs are right – 99% sure that the binding is the issue. Look how freely the linkage moves in that video, and how it always snaps back to the same place.
I think you will need to take the carb off again to get that linkage hooked up correctly. It needs to be put in place as you fit the carb back on to the engine so that you have enough movement to wiggle everything into place. It’s not right as it is now.
sadexpunkFull Memberyep, will do then, but one things baffling me. as you rightly say, the doobery springs back to the right every time until its pulled to the left and then springs back. but i cant see anything at all that would put any tension on it to keep it to the right. anything thats connected to it is to the left of it so youd imagine the opposite happening.
coolhandlukeFree MemberI did the filter, carb, oil, plug thing to mine. It was still crap.
Sold it for £40 and bought a brand new Honda.
Never looked back.
sadexpunkFull MemberI did the filter, carb, oil, plug thing to mine. It was still crap.
Never looked back.
i dont like things beating me, ill have another bash today. need to try and get tension on the doobery somehow to make it want to spring back to the right. if i cant, then i may have to go down the same route altho i probably wouldnt get £40 for a non-working mower 🙂sadexpunkFull Memberyeee ha, fixed it!!
this was the key. took petrol tank/carb off again and checked the doobery, it sprang freely back clockwise. slowly put it all back together again all the time ensuring it kept springing back as per that video, then struck it up. far better 🙂
bit of a dip as it went through the rough/high stuff but i can live with that, probably to be expected. if we keep on top of it it wont get as long as that again anyway, this is all from last year.thanks a lot for your help, much appreciated, this place is great.
[video]https://vimeo.com/208457283[/video]
ingwerfuchsFree MemberGood stuff. Now for the most important thing; a picture of your lawn with fresh stripes! I love a stripey lawn. 🙂
tillydogFree MemberResult! Well done 🙂
My lawn is available for extended trials…
glasgowdanFree Memberingwerfuchs – Member
Good stuff. Now for the most important thing; a picture of your lawn with fresh stripes! I love a stripey lawn.POSTED 7 HOURS AGO #
For your personal pleasure
The topic ‘lawnmower (petrol) engine – fix it or buy new?’ is closed to new replies.
