Viewing 4 posts - 1 through 4 (of 4 total)
  • knog frog led lights..
  • taka
    there ace little things
    got told today by a car driver how good they where they could do with sothing covering the to of the bulb for the rider as it blinds you when you look down and the flash is verry fast and destracting even so im thinking of getting 2 for the front cos there just that gud and cheap 😉
    review: 2009 Knog Frog LED Light
    Item: KNG100 Claimed Weight:"Claimed Weight" is an unconfirmed weight provided by the manufacturer. 18.0g
    $14.95/2/$14.00/4/$12.00
    For those of us who like to sneak out for rides before sun up or squeeze in one last hill repeat on an evening ride as dusk approaches, it's essential to have that little extra bit of visibility! However for most of bike fanatics, bolting a big heavy flashing red light to your bike is always somewhat nauseating, or the clamping device is ill fitting and a hassle to take on and off.
    The Knog Frog light is the perfect solution. Its small flexible body can stretch to fit almost any shape. You can wrap one around your seat post, handle bar, helmet seatstay or anywhere. We were very pleasantly surprised to see that it wraps easily around the tear dropped shaped seat post on Cervelo Soloist Carbon frames with ease. The Frog uses a single surprisingly powerful LED and one button which are sealed beneath its water resistant body. You have two modes of light operation, steady and flashing. The Frog will give you 160 hours of run time and weighs a miniscule 15g. The Knog Frog light is available with a red or white LED and red, black or translucent body colors.
    t
    Reluctant
    Do you work for Moore Large?
    taka
    nay why?
    paulosoxo
    They go on your helmet no bother at all
The topic ‘knog frog led lights..’ is closed to new replies.
