Although it is about the same height as my old bike
About simply may not be good enough, if you are sensitive to position like a lot of us are then even 5mm out can be the difference between a 100 miles without fuss and crippled after 10.
If you still have you old bike then get the ruler out and start measuring everything, set-back, height etc. and start by trying to replicate that on the new bike.
But you need to pay attention to other changes that may have happened too, lower or wider bars, shorter/longer top tube, even a different saddle can all mean that your body is positioned differently and consequently means knock-on effects elsewhere so you may need to fiddle around and experiment a bit too.
Plenty of guides online too but often you get a particular fitters POV pushed across and they don’t always agree about what is ‘right’ so take it all in by all means but work out what will work for you, not just blindly follow a formula as it won’t always work for everyone.
