Viewing 30 posts - 1 through 30 (of 30 total)
  • Just riding along
  • uphillcursing
    I think it will buff out? What do you reckon?
    gofasterstripes
    No.
    Can I have your forks?
    chambord
    Should be OK just keep an eye on it and make sure it doesn’t get any worse.
    cokie
    Looks like a sticker tbh.
    ThePinkster
    Might want to fit an angleset to correct the steering too.
    And a much longer fork to make it slack enough.
    jekkyl
    Wtf? How?
    monkeysfeet
    What frame is that? 😯
    fasthaggis
    Put an angle headset in ,be reet 😉
    RobHilton
    Snap!
    Well, bend…
    kraftyone
    One way of “tucking the back end in”
    uphillcursing
    JRA may have an element of BS to it.
    @Gofaster. No you may not. They seem to have survived intact. 1 1/8 Rebas who would have thunk it!
    wwaswas
    Impressive cordless drill alignment in the OP.
    gofasterstripes
    @uphill -bother.
    This looks like next years trend sorted.
    FatShortBikes.
    gofasterstripes
    What did you do, anyway? Straight into a bog at 30 with a short stop?
    I did that on a fully loaded Thorn Raven, luckily the forks were slightly weaker than the frame.
    uphillcursing
    Not sure about that. I did try to ride it like that. Was interesting to say the least. I may have just about managed it if the car was at the bottom and not the top of the hill.
    uphillcursing
    Can’t say at this point. SWMBO may look in on this thread and I will get grounded! 😳
    fasthaggis
    Only to you Wwaswas,only to you 😛
    jekkyl
    Jesus I’d be gutted, was that your main much loved bike?
    fangin
    I promise to stay and watch out for your SWMBO and cover things up if she does pop by. But put me out of my misery and tell me what happened…
    My less-than-parsimonius theory is running into a large fallen tree trunk suspended just at top of tyre height whilst belting down a hill.
    edward2000
    A huck to flat should put enough tension in the down tube to straighten it out
    rumple
    never mind the frame, wtf happened to the saddle? 😯
    nach
    That attempt at ghetto forward geometry did not go well.
    dvatcmark
    Did you run into a dog on a shared cycle path?
    uphillcursing
    Arboreal interfaces were very much involved in this. No wounds or broken bones were received thankfully.
    @ Jekkyl, no this was a spares box “bitsa”. I am a bit peed off but only because I was actually really enjoying the lightweight, back to basics hardtail thing.
    devash
    @ Rob Hilton
    Starting a reverse trend for ultra-steep head angles? 😆
    snakebite
    JRA and my forks just sort of broke. LBS reckon warranty job 😳
    unovolo
    Ran into Binners whilst cottaging in a hedge with Hora?
    matt_outandabout
    I see the cricket bat you smacked it with….
    brakes
    did you leave the handbrake off when parked on a hill?
    garage-dweller
    That’s some serious toe overlap.
The topic ‘Just riding along’ is closed to new replies.
