The upgrade itch has kicked in and im focused on changing my do-it-all ‘life bike’s’ brakes to something a wee bit lighter and more effective.
I currently use the tried and tested BB7’s with Tektro hood levers on a drop bar. However, Im fed up of skining my knuckles whilst adjusting the pads on the calipers and they are a fairly basic and heavy design at best.
I run an Alfine hub with bar mounted lever so single speed specific hoods/levers are what im looking for.
So, which of the above should I go for? Anyone got experience of them all?…
Pros/cons as I see it:
Juin’s – circa £100, retain existing hoods and mechnical function of cables, minor weight saving, close to full hydraulic power(?), funky looks, potential for heat build up to cause expansion in master cylinder??
Spyres – circa £120, retain mechanical functionality and hoods, fair weight saving, improvement in function over BB7 but not up to Hydro standards?
TRP Hylex – circa £190, new hoods, best lookers and lightest option(?), best performance(?), considerably more expensive, best to avoid full hydro option for potentially easier touring repairs?
