Yep, most likely the BPDU guard within spanning tree has shut the port down. More info here.
Sounds like you’re trying to diagnose a problem by using some software based packet sniffer? If that’s the case you’ll need to talk to your network admins to set a port(s) for you to use. If you’re going to do that just get them to mirror a port to your laptop and run the capture that way.
I’m sure you know this but if you’re trying to place your laptop in the data path of two other devices and capture their traffic you should expect a knock at your door!
http://en.wikipedia.org/wiki/Man-in-the-middle_attack
