Poltheball – yep. Eventually followd an newly cut access road alongside which they seem to be laying thick bore pipe? Road ran out before I saw any path up to the saddle between Mayar and Dreish so I chucked it. Any pointers? Though I won’t be back until next August!
@Poltheball – We are supposed to be going that way in a couple of weeks. Would be grateful if you have some local knowledge on that path and whether we need to reconsider our route
Once you pass the (recently rebuilt) cottage on your right near the top of the glen, you pretty quickly come to the end of the road; there’s a patch of trees (on the same side as the cottage; they’re the only trees that end of the glen), of which the west side is fairly straight. The Kilbo path runs parallel to the west side of the trees (heading north), pretty close by them, so if the path isn’t visible, just follow the line of the trees and you’ll pick up the path further up. The gamekeeper uses it with his 8-wheeler, so it’s fairly easy to find (tyre tracks etc). You keep heading up this track til you reach a t-junction; head left for Mayar/Corrie Fee, head right for Dreish/Kilbo path to Glen Doll forest.
Once you get up there it’s worth topping both Munroes (Dreish and Mayar) as they’re easy and the view is great; both are pretty bike friendly. The Shank of Drumfollow (Kilbo path heading down towards Glen Doll forest) is a bit sketchy, but about 75% rideable on a hardtail. Just whatever you do, if you feel like you’re falling off, bail to the left… Once the Kilbo path reaches Glen Doll forest, the track is absolutely ace after a stream hop or two; really soft and loamy with rooty sections, drainage ditch hops etc. You then pop out into a deforested area, which is a bit rockier but still 100% rideable, and you just follow the path down. It eventually reaches and crosses White Water, and you can head down to the ranger centre from there. Great ride, done it a few times and can safely say it’s worth it!
