Is this descent int...
[Closed] Is this descent into Hawes from the SW...
[#3811132]
...any good? Thanks in advance.
From summit of Ten Head to Gaudy House...
Paul
Posted : 26/03/2012 7:42 pm
Linky not working
Posted : 26/03/2012 7:44 pm
 ton
it is quite good.
starts off with a contouring track, then turns into a very fast grassy swoopy downhill, and the last bit is quite rough, if i remember well.
Posted : 26/03/2012 8:36 pm
Thanks Ton.
Hopefully this link works...I was wondering about the nearby alternatives as well.
[url= http://www.streetmap.co.uk/map.srf?x=385330&y=488375&z=120&sv=385330,488375&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=775&ax=385330&ay=488375&lm=0 ]Map linky[/url]
Cheers...
Posted : 26/03/2012 9:35 pm
 ton
the one to the left of ten end, is a rocky rutted peach of a track too. especially the section at the side of the woods.
Posted : 26/03/2012 9:38 pm
All BWs into Hawes and around are pretty cool and you can link them together for quite a few routes that are all interesting and quite compact around a single area! Or head south over the tops for a biggy. Also, go a bit further north to Gunnerside.
Posted : 26/03/2012 10:20 pm
We were heading back to Ribblehead but will give you an idea
Rough bit Ton mentions
Contouring line to Ten End
Approaching Ten End where the two tracks meet
Above Snaizeholme. Ingleborough in distance
Posted : 26/03/2012 10:37 pm
Ace, thank you. Will be taking PBW from Settle then drop into Hawes and Lady Annes Highway to Kirby Stephen.
Train back to start...cheers.
Posted : 26/03/2012 11:21 pm
