Is there anything l...
[Closed] Is there anything like a 135mm spaced Pompino?
[#2995693]
Since On One don't make them anymore
Want to build something up SS with some 130mm wheels I have, but have the option to bodge on gears or a hub gear later
Surly cross check seems the only much more expensive option
Or 2nd hand
Posted : 30/07/2011 8:41 am
 JRTG
Yep crosscheck is goodun, have a nice battleship grey one that is ace. Often sh ones on eBay.
Posted : 30/07/2011 8:55 am
 Olly
slotty inbred is ideal for my wishes.
simple Single speed around town.
MTB gears for touring 🙂
hope bulb hub, so quite happy taking a SS conversion kit.
will take up to 32C tyres in the back, and anything you want up front.
Posted : 30/07/2011 9:06 am
I found no problems re-spacing the rear end of my pomp with a block of wood and a crow-bar to accept an Alfine. Put thousands of K's on it since then, on and off road with no issue.
Posted : 30/07/2011 9:11 am
Inbred too long as I want to run midge bars (plus I have an Inbred already)
fourbanger, did the paint all crack?
Posted : 30/07/2011 11:44 am
The wheels you have, would they respace with the washers?
or is that not viable?
[url= http://www.sheldonbrown.com/frame-spacing.html ]Sheldon - on frame spacing. [/url]#
Posted : 30/07/2011 12:21 pm
