i found one problem….
the seat tube has a clamp size of 28.6 (mainly used for road frames) but my mech is desighned 34.9 (MTB size seat tubes) so ive but a rubber shim to adapt it. this means the mech plates that move the chain are slightly further away from the frame than they should be, and when i put the chain onto smallest chainring, it rubs.
even though the L srew is all the way in, the mech cant close up any more.
so i need a BB with a slightly longer axle, so the chainset is also slightly further away from the frame and therefore not rubbing the chain
??i hope that makes sence…… one problem solved at least
