I don't know what the fuss is about using a granny ring. It's a very useful thing to have in many situations. It's also assumed to be only used by unfit riders or for tackling the steepest of climbs.
Personally I find it of most use on the most slippery climbs and not necessarily the steepest. I'm thinking of a wet grass covered clay hill, where you need to sit to get weight down and any attempt to power up would result in wheel spin. The same applies to snow and ice covered hills.
Though to me walking a hill is not an option 8)
I think a light, 3 speed hub gear would be the ultimate set up. 1 gear for silly steep climbs, 1 gear for blasting along roads and the middle gear for everything else.
...but why just have 9/10 gears when you could have 27?
To start with, you don't have 27; you only have around 17-20 usable gears.
A 1x9 has all 9 gears usable and a 2x9 will give you around 14. A 1x9 or 2x9 obviously limits the amount of gears you have available, but it doesn't necessarily limit the trails you can ride - you just ride them differently. Your fitness will change and your technique will change and you'll find that things you would have once used the granny ring for you will now do on what used to be your middle, for example. If you like riding with the adaptation of technique then 1x9 or 2x9 is good; if you don't like it or you can't adapt then revert to 3x9. Nobody can argue with you into understanding or liking it, you just have to try it.
See, I find that a granny ring just makes me spin out in such situations. I end up using a higher gear to avoid this.
Pfft. Ok then, you sit there spinning away like a mad 'un, while I overtake you pushing my bike. 🙂
Same here, want to get something like that for my road bike eventually, although it might be hard finding one that's 120mm spaced or whatever track dropouts are!
11-36 sram XX 10speed
11-34, 9 speed
11-30, 8 speed
11-28, 7 speed
so: granny is usually on a 9 speed rig is 22 front & 34 rear is 17.1 gear inches
singlespeeders on 34:16 are on 56.1 Gear inches
with a
10 speed on 32 front your lowest ratio is 23.5 gear inches
9 speed on 32 front your lowest ratio is 24.9 gear inches
8 speed on 32 front your lowest ratio is 28.2 gear inches
7 speed on 32 front your lowest ratio is 30.2 gear inches
to put that in context:
if you can ride your trails with dropping below small ring and half way down the cassette (22:24) your gear ratio is 24.2 inches
in summary if you take 10speed with a 36t front ring = 26.4inches
you might as well stay with your existing 32t front 9 speed 24.9 inches, give away a little on the top of the ring and save yourself £100's in upgrading shifters, chains & other odds & sods
no?
It's whatever works for you innit?
am happy with 2x9. my commuter is 1x8.
think about chainline though.
I think that the biggest influencing factor in bike configuration
is where you use the beast to do the bulk of your riding.
horses for courses.
So what you're after is what they raced on seventy years ago? Three speed hubs with a lever on your 'North road bars' like modern niché offerings.
Don't get me wrong I'd try 2x10, but frankly it's a expensive thing to try as I tend to keep one bike and replace the bits as and when. I couldn't justify flogging a perfectly good XTR set up really.
But the crucial thing is, at no point ever do I feel when riding that I am missing something. The 27 gears I have seem to cover everything regardless of what is deemed by others not riding my bike as useable.
Edit;Forgot to mention I usually run an Ultegra 12-25. The shift across gears in 34t is sooo smooth, and the 25/granny combo will get anyone up anything Wales, Peaks or Chilterns has to offer.
More than content with my 3x9. it does what i want. I suspect I spend more time in the big ring than most on this site judging what people are saying anyway. may change the lot when it wears out, then again maybe not...
This is what most people who ride 1x9 would say, too.
Exactly, it would be change for the sake of change I think. If for some reason my running gear just disintegrated overnight then I might think about it. I did run singlespeed almost solely for eight years and rode all my 24 solos and some epic rides on it without a problem so I've nothing to fear about the number of gears as such.
One thing that puts me off, though I'm sure the new 2x10 is much better. Was using a Duo, the front changing was dreadful.
Three_Fish - Member
POSTED 1 HOUR AGO # REPORT-POST
How do you only end up with 14 useable gears from a 2x9 setup? Don't most double setups run a bigger middle ring to cut down on overlap?
Me, I'd miss my big ring - can't stand all this spinning.
+1 oldgit, I've looked at going 2x10 too, but quite frankly I've better things to spend the cash on than throwing a perfectly good XTR groupset away - and the spread of gears with 2x10 are less, so I'll either be under or over geared compared to a 3x10 combo with a 34 out back.
A few people are getting overly evangelical here methinks 😉
I can see the attraction of 1x9/10, but it all depends on what and where you ride. My regular loop has a few sections that go from being a bit dull to quite challanging just by putting a bit of effort in and cranking into them on 44x12.
well cy @cotic sent me this ramble, he should have just posted on here.
With the advent of 10spd drivetrains, there's been a lot made by the media and the manufacturers about the best way forward, and your options for tailoring your drivetrain to suit your exact needs are wider than ever before. However, with all this choice seems to have come some already pretty entrenched views and my-drivetrain-preference-is-better-than-yours pack/clique type behaviour. When the name-calling starts, I find my natural tendency is to look at all sides of the arguement, so here's some of my thoughts.
The main crux of a lot of the arguing seems to revolve around a seems-like-singlespeed-zealots-the-first-time-around macho posturing regarding an obsession with ditching 1 or 2 of the front chainrings now we have these massively wide ratio rear cassettes."1 x 10 is the only way forward! You can use a chain device! Why would you use a lower gear when you can walk?!!"
"Why have Shimano persisted with 3 chainrings? Surely 2 x 10 is the way forward?!! Similar spread, less duplication, why would you use a lower gear when you can walk?!!"
From the macho overtones, a lot of these arguements seem to dismiss the need for a tiny low gear on a mountain bike, as if you're some kind of wuss for liking spinning up hills, and you're in some way not hardcore enough (as if that matters) if you're not NEEDING a bashguard/chain device, or yet further that you're some kind of moron for having lot's of duplication of gears in your drivetrain.
I'll admit to something of a vested interest here as I'm a long time triple chainring user. It seems somewhat unfashionable these days, but I've never run into trouble with wrecking outer chainrings, so a bashring hasn't really been necessary. When I've used double/bash set ups before I've either found them noisy and unreliable (32t largest chainring, constantly bouncing out of gear on the 11 or 12t sprockets at the back, noisy chain slapping on the chainstay despite being very tight for the setup), or I've not at all got on with the big jump between front ratios (on a 22/38 where I found it very hard to deal with the big gap when dropping from 38 to 22). So, I've always come back to a triple, usually 22/32/42. It suits my spinny pedalling style, and I HATE pushing my bike up anything, I like the challenge of a techy climb, and sometimes (whisper it) I'm so tired from a long ride I can't push a gear any bigger than that, so 22/34 is lovely thanks.
At the other end, as soon as the trail points downwards, I like running in the big ring/middle of the cassette which keeps the chain nice and tight and quiet and out of the way of the frame. I prefer this. On my hardtail I can push an even bigger gear really slowly to help calm the bike down over rocky sections (it's one of the keys to going quick on a hardtail in my experience), and on a full sus you get much less pedal kickback effects in the big ring so your suspension actually works better. It's a minor thing, but doing what I do, I like knowing that.
In between I like small jumps between chainrings which make managing gears on climbs easier, and whilst lots of gears means lots of duplication, it also means much closer ratios by-and-large, and I like that too.
However, I'm not trying to win you over to my way of thinking at all. Most of the guys I ride with use double/bash. Yet another group I know have a lot of singlespeeders. My point is that I don't go around pointing and sneering at them for their drivetrain choices, and neither should anyone else sneer at mine. That paragraph above simply illustrates that I choose to run triple front and a tiny low gear because I've tried some other options and didn't like them, so triple is my preference. It's not right or wrong, good or evil, it's just my choice because I feel it's right for me. So, personally I'm over the moon that the advent of 10spd hasn't heralded the death knell of triple chainrings, from the Shimano side at least, and actually their new closer ratio front set up would even more closely suit my riding style. Which is nice (for me!). By the same token, I couldn't be happier if you think a SRAM 2x10 set up or a 1x10 with a chain device is a dream come true for your style of riding. That's your preference, and having the choice is great, isn't it?
So, by all means give 2 x 10 a shot. Hell, ditch the lot and go 1 x 10, see if I care! If you don't like it, put some more chainrings back on. Just don't go around slagging other people off for not using your new Way Forward. They're probably quite happy with the set up they have, could have even put some thought into why they like it. We're talking about ways to have fun on a bicycle in the dirt here. We're not curing cancer. So if you do see me on that steep climb twiddling away in my tiny bottom gear whilst you're pushing up on your chain device'd 1x10, I'm having a lovely time thanks, just like you.Cheers,
Cy
www.cotic.co.uk
07970 853531
Can't be bothered reading all that. Got a synopsis?
choice is a good thing, do what you like, its terrain specific, now im going to fight my corner regarding my choice. true stw pedigree.
I was referring to many 2x9 set-ups which are achieved simply by removing the big ring from a 3-ring chainset; but the limitations are on the granny ring and cross-chaining to smaller sprockets on the cassette. I don't know if 2-speed chainsets have the gears moved outboard to improve the chainline. I suspect that they don't, though.
Another thing; I have found since getting a KS I900R adjustable post with remote, I hardly use the granny ring, I have found that I can run my seat higher for climbing efficiency than I ever could with a fixed seatpost, as I can now adjust the position down an inch or so for singletrack or slam it for downhills.
So in reality, I find myself using the seatpost remote INSTEAD of the front shifter, and its amazing what you can climb in the middle ring with your seat at the optimal pedaling height 😉
I'd definitely go for 1x10 if I was speccing a new bike - would suit me nicely. It's not that big of a deal to start changing the drivetrain right away though.
Not hung out with granny for years, at least in the UK. She has her place - really long and sustained climbs (ie 1 hr +) where you need to drop down and get into a rhythm - so few of those here though. You'll get a gear ratio of 1 with a 1x9 or 10, which is pretty low - you can spin up things nae bother on that if that's your style, it's not like you're mashing.
Also good to have the granny if you're doing a really long ride and hit a rough patch. It's a good bail out gear if you've got nothing left, just spin the legs really easy until you feel a bit better.
I'd be interested in demo'ing it.
Garry to be fair, though we don't have big mountains we do have steep climbs even if they're only 100' long. Surely every one has an 'impossible hill' local to them?
I only know of five people to do ours, take away the granny and I wouldn't know any.
We'll see how it evolves I think. When I think about the huge numbers of riders walking hills that most 'lets say very keen' riders would ride, I couldn't ever see it being offered as the norm.
My 2x9, 11-34 22/36 bash I have 15 yueasble gears - 6 on the granny ring and 9 on the 36. I can get to all 9 on the granny but it is ridiculous and there is some overlaps.
Removing the overlaps yo have 12 gears 0- the 9 on the 36 and the bottom 3 on the granny as 3-6 on the granny are obverlaps with 1-3 on the middle.
I do use the 15 gears however.
I Shift down to the granny ring on steepish climbs early and use 6 gears in granny - its closer ratio that way. 6 nice close ratio low [b]mountain[/b] climbing gears.
Why anyone who goes up significant hills wants to mash up at a low cadence in a high gear is beyond me. If you live in an area with no long steep hills then the granny ring might well be redundant - but I climb hills of a thousand+ feet at steep gradients. Some climbs can take a couple of hours of grinding along. its not mashing a high gear for a few minutes
What I'd like is the aforementioned 3 speed sturmey archer with 6 bolt disc mount
There's plenty of local climbs I cannae make, rest assured on that score. But it's down to not having the legs and lungs, not the gears. If I can't get up it on 1x9 with a 34 at the back, then I aint getting up it with the granny, by and large.Garry to be fair, though we don't have big mountains we do have steep climbs even if they're only 100' long. Surely every one has an 'impossible hill' local to them?
One or two exceptions probably - I ordered a granny 😉 from CRC a while back with the intention of fitting it for this one particular climb where I reckon it might make a difference. Not got round to it - maybe I'll be converted back to the triple if it works out.
The challenge. For some of us it's all too easy, so we do stuff to make it a bit harder 😉
For me it makes it feel like more of a workout than sitting there spinning. And being fat, I need all the workout I can get!
Steven - righteo - next pentlands ride you make it to we will find a speshully extra hilly route for you only
i got a 38/26 double set up with a 11=34 cassette and its great for trail riding and xc done the london to brighton off road with it today. find i usually have enough to pedal up an down with this set up.
rode my ss all winter up to the middle of July, only rode my geared bike once and that was up at Loch Muick and even then it was more about longer forks and bigger tyres. Done plenty of hilly rides on Wed evenings on the singlespeed, don't think anybody had to wait on me. Also did the ride up at Pitlochry and don't think anybody had to wait on me that day either. Rob seems to have been doing quite well on the hilly routes recently anyway, don't think you need me along to make them any hillier. If I have to walk a climb on a wed night chances are I won't be the only one and won't be the slowest either.
steve - only teasing.
Thing is how did we manage before full suss, or long travel forks, or hydraulic disc brakes etc, we just did and still had fun. Same thing with gears. if you only had nine or ten you'd still manage up most of what you do now. And mostly with a smile on your face. Just get out and ride.
Kinda gone off the point here, the OP was asking about a 1x9 on 5/6" travel bike not what if any gear people 'needed' to go up hill.
For general trail riding on a 5/6" travel bike, which is what you asked about 3x9 or 2x10 surely has to be better than 1x9. I've never ridden anything as big as 5 or 6" travel, but I would imagine that to get the best out of such a bike it would necessitate a good range of gears? Wether it be a granny ring to dance it up a boulder strewn climb or a big ring to hoon it home down the hillside on.
What you can do on a singlespeed is a whole other story, but you're preaching to the belivers on this site.
Can't argue with that, totally true.
However the technology is out there to be had if you want it. My cynical view is for who's real benefit is that technology?
I've been guilty of buying the next new thing in the past, but I like to think I'm a bit wiser now.
Depends on what is meant by general trail riding, to me, for what I consider general trail riding then 1x9 would be fine. Did get a bit sidetracked by ssing but my point was that for me I'll happily ride pretty much anything on a ss so wouldn't have a problem with 1x9. But each to their own, which is one of the reasons I love mtbing.
This is just the next fashion thing, like bashguards. [u]The Are Not Needed If You Can Ride A Bike Properly[/u]
And to be fair, elastomer suspension and cantis were the pits.
"djglover - Member
This is just the next fashion thing, like bashguards. They Are Not Needed If You Can Ride A Bike Properly"
What a strange post. You realise that the entire point of 1x9 or 1x10 is dispensing with things That Are Not Needed? And why do bashguards show you Can't Ride A Bike Properly? Do you never catch a chainring? Or is the sort of riding where ground clearance runs out Not Riding A Bike Properly?
_tom_ - Member
'...a light, 3 speed hub gear would be the ultimate set up...'
The [u][b][url= http://www.sturmey-archer.com/products/hubs/cid/3/id/17 ]S-A S-RF3[/url][/b][/u] is available in OLDs 108, 117, 127mm. I have one on my general purpose Pompino.
richcc - Member
What you want is the [u][b][url= http://www.sturmey-archer.com/products/hubs/cid/8/id/59/specs/1 ]S-A CS-RK3[/url][/b][/u] and the bonus is it has a cassette freehub so you can also run a derailleur and have a silly amount of gears. Available in black or silver.
I got rid of my big ring a few years ago and use a 34t 'middle', a 22t granny ring, 11-34 9 speed cassette and a home-made bash ring (which has had some bashing). The granny ring is a steel Blackspire Chuck ring which has lasted for a long time.
Removing the big ring gives a usefully improved ground clearance for rocky trails and logs.
I don't use the granny ring very often, but I can't see any reason why I should totally remove it. It hardly adds much weight and does give the option of a couple of lower gears (fitness not great at the moment).
Aristotle - removing the granny also removes the front mech, cable and shifter. Add a few grammes back in for the chain device, but most people end up saving 350+ grammes, which is pretty significant.
I only weigh 60kg so I have found that bikes feel really hefty above 28lb, so I do tend to keep an eye on weight. I've added an uppydowny seatpost and fatter tyres recently so any loss is a bonus.
The main reason I'm interested though is simplicity. I find I don't really bother with biggish gears, and I'm definitely a spinner.
Once I get paid, I think I'll take a punt on the Widgit chainring in a 28t size - then maybe add 10sp once we get the other side of the winter.
I'm open to it not working, but I fancy giving it a go. Once you look at the gear ratios and you realise that a double and bash only really gives 13 usable gears, it does seem a lot of faff to have all that extra kit for those 3 or 4 extra gears.
I'm also interested in how people get on with the Alfine 11 and how high a torque it can cope with. I don't want to give up my granny gear, but I am pretty happy (at least in theory) giving up pedalling above 22mph.
