Friend of mine had to get his LBS to remove his press fit BB to access the BB shell and reach the internal cable for the front mech. Presumably the cable is fitted before the BB during initial assembly. If something as simple as a cable swap cannot be achieved at the trailside, then the design is one of form over function and of little use.
Yeah, that’s not a great design. Though mitigated by it just being the front mech and so easily dealt with. Most people don’t carry spare cables so it’s generally a non-issue trailside, distance dudes should probably be considering things like this when buying. But it’s bad if it’s impractical to do in a home garage.
(I’m totally blaming bloody stupid pressfits though!)
Doesn’t have to be like that though. Like, my 224 had semi-internal cables but totally outer’d so changing an inner was exactly like any others. Not that I carried an inner when I was riding it but, you get the point.
