I’ve got one have the current tracer 275c in XX I’m 6’1” fits fine.
Pedals really well, I swapped the bearings on lower link to full sealed rather than the open sided ones as we live in the U.K. and it’s wet, but it’s aomehring I’ve done on all bop bikes I’ve had
The axle on the rear wheel only needs a 5mm hex key and it’s really easy to use. Loosen the collet and then wind out the axle, job done.
Looks neater than a Malle axle or DT Swiss through axle too
Can’t say I’ve had any issues with the routing under the B.B. if you give your hose and cables the correct length.
The internal call routing works a treat really well constructed
Yes the upper link does rub the seat stay on the swing arm a little with dirt in there.
It rides better than my geometron I used to have and also my nomad mk3 before that.
I’ve ridden a mk4 nomad the tracer climbs better and descending I couldn’t see any difference between the two.
