check youve not knocked the compression on?
or check the rebound?
i run around 100psi i think, maybe even less (80psi), and im 72kg, the RS figures are WAY out in my opinion.
set up the +ive for the sag you want, then increase the negative to vary how active the forks is
iirc, it shouldnt really be further than 10psi away from the +ive
have you tryed cycling the fork a few times (compressing it and extending it) with no pressure in it, possibly even upside down, to get the oils moving around the systems again…..
set it up so it works for you, and then adjust it if it loosens up over time, buy increasing pressure?
worst comes to worst, send them off to get them pushed….?
