Inbred/Scandal 29er...
[Closed] Inbred/Scandal 29er - 18 or 19.5?
[#3879602]
At 6 foot I seem to be in between sizes
Would I be better off with an 18" and a "long" stem or a 19.5" and a shorter stem
Posted : 17/04/2012 10:37 am
 ski
What sort of riding do you do jamesgarbett?
The 18" would be more fun on tight singletrack I guess, but if you want a more racy streatched out long distance machine, I would go bigger.
18" is what I would go for btw.
Posted : 17/04/2012 10:40 am
I'd go 18in unless you are very into head down and hammer along.
Posted : 17/04/2012 10:41 am
I am 6ft and ride 2 (not at the same time) 18" Scandal 29ers, i did try a 19.5" but found it slightly too big.
Posted : 17/04/2012 11:22 am
5,11" with 33 inside leg - i went for the 19.5 as I dont like running a scaffold pole seatpost. works for me
Posted : 17/04/2012 12:30 pm
I'm only a smidge shorter than you and wouldn't even think about the 19.5" frame.
Posted : 17/04/2012 12:33 pm
I'm 6' with 33.5" inside leg and 19.5 inbred 29er fits me and my riding spot on 😀
Posted : 17/04/2012 1:22 pm
6'1" here with a 32" inside leg and find the 19.5 with a 90mm stem fits me perfectly.
Posted : 17/04/2012 3:15 pm
 mboy
Same measurements as you, and I got the 18", on which I didn't even need a 350mm seatpost at full extension.
I've ridden 16" frames before (which were too short in the TT admittedly) with a 410mm Thomson and had room to spare to raise the saddle more.
I will echo Brants comments. 18" unless you want a real racers stretch.
Posted : 17/04/2012 4:46 pm
 Bazz
6 foot, 33 inch inside leg and i went for the 19.5 with a 70mm stem. Used to have a 18 inch 26er Scandal in 18 inch and found that a bit small with a 90mm stem and a 350mm seatpost at max extension so i went up a size for the 29er, much better now.
Posted : 17/04/2012 5:14 pm
My sizing was based on on-ones recommendation - seems ok. In an ideal world I'd have a 19
Posted : 17/04/2012 8:50 pm
18" I would say!
Posted : 17/04/2012 8:56 pm
18" I would say!
but youre only 4 foot 2 so how would you know? 😀
Posted : 17/04/2012 9:01 pm
I'm 6 ft and have just bought a 19.5 scandal feels a smidge big - haven't spent much time messing with stem etc but it would make a good long distance muncher as opposed to tight single track fighter
Posted : 17/04/2012 9:03 pm
Your still up then Slapper!
This place is full of people who think that they are taller than what they are! 😉
Posted : 17/04/2012 9:18 pm
5'9" here & loved my 18" Inbred with a 50mm stem. But I'd say I was right at the bottom end of its size range. For the ambling/mincing/last-of-the-summer-wine type riding I do it was fine. I think 18". And a 70mm stem.
Posted : 17/04/2012 9:26 pm
