Sorry, my figures were converted wrong way but:
My file size (raw jpeg, saved from paintshop – not that I'm sure this is how mpeg is constructed so not entirely accurate sizing) is 12kB. That's
12000 bytes.
12000 bytes = 96000 bits.
30 of them a second:
360 000 bytes = 2 880 000 bits
So you'd need to be sure whether your card speed was quoted in bits or bytes per second – 8 bits in a byte.
Edit:
Card classes are quoted in bytes per sec so:
If this is the correct data save rate (i.e. if your system uses mjpeg rather than mpeg) then you can get away with a class 2 (2 megabytes per second) as you only use 1/3 of a megabyte per second at 30fps.
