I'm too stupid...
[Closed] I'm too stupid to understand brake bits!!!!!
[#1957525]
I have a pair of xtr M966 dual control levers and deore M525 calipers. What hose type bits do i need to join the two together. Thanks for any help
Posted : 03/09/2010 2:10 pm
is this the right thing?
http://www.chainreactioncycles.com/Models.aspx?ModelID=14854
Posted : 03/09/2010 2:17 pm
That should do it. IIRC the caliper needs the banjo fitting and the lever has a screw in fitting.
Posted : 03/09/2010 2:20 pm
my (old, black) 525 calipers are screw in.
Posted : 03/09/2010 2:27 pm
once i get the bits is it pretty self explanitory or do i need a shop to do it?
Posted : 03/09/2010 2:28 pm
Other way round I think. The Banjo connector fits both ends of the full XTR set up, so for an XTR lever / Deore caliper you'd need a banjo one end and straight connector the other. ie: what you have linked.
Posted : 03/09/2010 2:30 pm
easy to put together if you follow the instructions. Can you then bleed a set of brakes? Also not difficult, but you know your competence level.
Posted : 03/09/2010 2:32 pm
i've never tried bleeding brakes on a bike but have done on a car. same idea i think. and i've got some bike savvy mates!
Posted : 03/09/2010 2:37 pm
Your only right jonv. So the link is the right hose but banjo to the lever end and nut into the caliper.
Posted : 03/09/2010 2:40 pm
cool. you guys are the best!!! 😀
Posted : 03/09/2010 2:42 pm
Be gratfeul they're not banjo to banjo fittings, a royal PITA to find unless you go goodridge!
Posted : 03/09/2010 3:06 pm
I'm pretty mechanically apt, but have never really/successfully figured out disc brakes: bleeding, adjusting, etc., so just end up taking it to the bike shop and they do whatever is needed quickly where it would take me hours (and still probably not get it right).
Posted : 03/09/2010 6:07 pm
